Silverado Lift
Silverado Lift
I am getting a 2003 or 2005 Silverado 1500 Extended cab with Z71 package. I want to lift it enough to give it that jacked up and ready to mud look with some good size muddin tires. Need recommendations on how much to lift it, how to lift it, and what size tires to get.
There's a 6" suspension with 3" body lift or you could get cognito 7-9" lift...or I think fabtech makes a full drop 7" and you can crank on that an inch or two
You can crank your stock torsion keys or buy aftermarket..usually 2.5" of lift or so come from them. So a cognito, fabtech, or pro comp full drop kits will get you 6-7" of lift and then you can crank on top of that. But with crank the ride gets worse
Jgill1992
Silverado & Fullsize Pick-ups
May 1st, 2014 5:40 PM
58chev
March 2nd, 2012 10:32 AM
Rlock4227
Suspension & Tire
February 19th, 2012 11:26 AM
