Help with NV3500
Help with NV3500
My Name is Jason and I need help with my Chevy C/K 1500
She has a manual 5 speed
Now I have already take the previous transmission out and to a shop, After getting told i would need a rebuild here is what I'm left with.
What I need help with is This bracket just under the shifter Tower.
Can this bracket be replaced? Without too many problems, and would anyone know of a relaible source for this part?
Where the bearing sits, (my finger is) is starting to break so I was looking to replace the bracket and the small bearings.
Bowz Tied (October 30th, 2021)
I feel your pain... My 93 CK1500 wouldn't shift into 5th or Reverse when I bought it for cheap... taking the shift tower off revealed (as I expected) a broken 5th/reverse fork, but also the same bracket as in your picture, only broken in half with no bearings and the spring on the forward side was missing its tangs. After much searching, I have seen only one diagram of the single-rail shifter that includes these pieces... described as a Hydramatic, I believe... and so far, no vendor with a listing. If I can't find the parts (and if no further damage was done as a result of those pieces falling into the case!) I guess I'll have to bite the bullet and buy a used or rebuilt unit.
