horn location 2002 FOUND IT !!!
Edit finally found it!!! chiltons was wrong, Google was wrong. My single horn was located behind the Drivers lower DRL headlight assembly. I added a second horn and now mySilverado sounds like real truck
Hello All, I am a "new" Silverado owner. I just purchased a 2002 single cab 1500 with V6 and 5 speed. with 110K miles. The previous owner installed cat back duals and I am installing a K&N FIPK and a Jet programmer (more interested in reading codes and the new real time feature it has.
Anyway I think I should have dual horns but am only hearing one, so two questions"
Single or dual?
Where is/are the horns located? I looked under the bumper, under the hood, behind the headlamps, where the cat hair is the location?
BTW my "other" chevy is a 1965 C10 SWB with 350 and 700R4 , that I added A/C, power steering, front Discs, Power booster, 650 Holley, headders, Pentrox, and Lokar shifter.
my other car is a Miata , sure cant haul too much from Lowes in that thing ...
RE: horn location 2002
thank you for the welcome and the reply,,, however I pulled the plastic piece cover between the radiator and grille and there is no horn in front of the radiator...or at least what i think should resemble one !!!
thank you for your suggestion, but no one as of yet has been available to honk for me ... , with the wealth of knowledge here I assumed so one knew, I did a google search on it and the only usable hit I got was that it was under the bumper area ....I will just ask the dealership mechanic
1978 Chevrolet C10 half ton horn contact/ horn wiringI have a 1978 Chevrolet C10 that it's horn does
isaac_22
Silverado & Fullsize Pick-ups
December 26th, 2007 9:23 PM
zulu
March 28th, 2007 4:58 AM
