Notices
Old July 24th, 2015, 1:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community expertsBrowse all: Brakes
Print Wikipost
I think its my Brake Master Cylinder
Old October 3rd, 2008, 6:02 PM
j97chevy's Avatar
Default I think its my Brake Master Cylinder
first of my break pedal goes right to the floor.
When i step on my breaks, i hear something like air
I think its my master cylinder,
and other ideas?
thanks guys
97 chevy c/k 1500
Old October 3rd, 2008, 6:41 PM
Deltavox's Avatar
Default RE: I think its my Brake Master Cylinder
Might be a stupid suggestion but ive had something similar happen in my old cavalier, broken brake line, no fluid so its basically pressureless. Check your brake fluid to vito this possibility
Old October 3rd, 2008, 7:06 PM
j97chevy's Avatar
No broken break lines, i checked when i did my breaks..NO LEAKS
fluid looks good just black.
no i dont know if its the brake booster or Master cylinder, any way to pin point that out
Old October 3rd, 2008, 9:36 PM
ukrkoz's Avatar
brake pedal goes down to the floor + hissing noise= leaking booster diaphragm. diaphragm can be serviced seperately or replace booster.
otherwise, brake fluid level will be lower than it's supposed to be and you'll have obvious signs of brake fluid leaks somewhere.
Old October 4th, 2008, 10:31 AM
ukrbyk's Avatar
ok, here it is from a book:
1. depress the pedal and start the engine. if the pedal goes down slightly, operation is normal
2. depress the brake pedal several times with the engine running and make sure that there is no change in the pedal reserve distance
airtightness check
1. start the engine and turn it off after one or two minutes. depress the brake pedal several times slowly. if the pedal goes down farther the first time but gradually rises after the second or third depression, the booster is airtight.
2. depress the brake pedal while the engine is running, then stop the engine with pedal depressed. if there is no change in the pedal reserve travel after holding the pedal for 30 seconds, the booster is airtight.
i am not the one who wrote the instructions.
Old October 4th, 2008, 5:06 PM
j97chevy's Avatar
thanks,
i will check it out and post it up
Suzook250
Express & G-Series Vans
March 7th, 2014 4:22 PM
qzack1
August 28th, 2011 12:50 PM
randys94
May 14th, 2009 9:39 PM
new2chevy
11
April 25th, 2008 3:20 AM
Quick Reply: I think its my Brake Master Cylinder
