Notices
Intermittent Grinding sound at any speed
Old February 1st, 2014, 6:54 PM
kpowell3's Avatar
Default Intermittent Grinding sound at any speed
Hello guys i'm new to this forum as well as new to truck repairs. My current truck is a 2001 Silverado lt 1500 extended cab with 4wd. We bought the truck a year ago as a cheap work horse and snow machine. We now love the truck and are going to invest in getting her in better condition. The first problem is this intermittent grinding/vibration from the rear axle, it happens at any speed and is very loud. It started happening after a good 750 mile commute to pick up some goods from a different state. The cargo wasnt too heavy just a engine hoist, engine stand, and a drill press. The vibration/grinding comes on at any speed and goes away after hitting bumps or sometimes just goes away for no reason at all there is no way to predict when it will come or go. After a little investigating I narrowed it down to the left rear wheel. I pulled the left axle shaft out and found a MANGLED axle end seal. I looked in and saw the bearing but It appeared to be ok. The wheel has visual play when driving but no play in the wheel when jacked up with my hands at 12 and 6 or 3 and 9. The axle shaft has some grooves in it that I can feel with my bare hands but they are very little. Do these grooves (as seen in the picture) make the shaft unusable? I'm new to rear wheel drive axles and am not sure if these little grooves total the axle. I also took a snapshot of the bearings they seem to function fine and I packed them with grease and they rolled with no problem or resistance. My ultimate question is "could this shaft be causing the vibration/grinding sounds?"
Thanks,
Kevin.
Old February 2nd, 2014, 5:58 PM
kpowell3's Avatar
anyone? bump
Old February 3rd, 2014, 6:18 PM
JK23112's Avatar
Wheel bearing? Universal joint?
Just two things that come to mind.
T-bone
March 6th, 2012 3:33 PM
5:00 PM
Express & G-Series Vans
January 7th, 2012 11:38 AM
cupofchicken
December 16th, 2011 3:12 PM
bpeter3429
July 22nd, 2010 9:02 PM
anderhill
Astro
June 21st, 2010 9:07 PM
Quick Reply: Intermittent Grinding sound at any speed
