lol what's going on with my car battery
Hello
I just tested my car bettery and it had 16 volt lol and when i turn on the car it reads 17
anyone know what's going on D
i reved the car few times before i did the test i don't know if that was it.
It's an old digital meter but i have to say that it's been acting up haha... I'll use a different meter and see. The reason i was testing the batter was because my battery gauge fluctuates.. I opened the instrument cluster but got to a point i didn't know what to do.. there was a wire running from steering column the cluster.. i believe it was for gear indicator or whatever it's called ..
anyway.. i was going to test battery and alternator and then move on to battery gauge motor in instrument cluster.
New User
Awaiting E-mail Confirmation
I'm going a little off topic here but just in case you are over charging... If you pull the alternator remember to unhook the battery because today my roommate had me rushing to pull his off the sierra and i went to pull the rubber boot over the terminal end off the back of the alternator and dropped the wire and it hit the high rise aluminum valve cover and arced and I jumped off the truck and BOOM something exploded and smoke went every where. nothing was on fire... I thought the redtop blew up but it was smoking from the valve cover... it ripped the valve cover studs out of the head and blow the gasket out.... My best guess is the crankcase had fuel vapor and when I arced it they ignited.... I think somebody's got to much blow by...
It turned out it was the multimeter. I fixed it and tested battery and alternator with it again and everything was fine. I wanna know if the fluctuating battery gauge is because of not enough grounds?
cowboyfromhell
Silverado & Fullsize Pick-ups
June 5th, 2007 9:31 AM
