Low air flow on A/C
Low air flow on A/C
I get a very low amount of air coming out of my A/C when on any speed. The switch works fine and I hear the fan which sounds like is it blowing hard. Just not getting the air.
2000 Chevy Silverado Z71 extended cab.
Thanks for any help
Thanks for any help
I doubt if that is it but I will check. I will do that and see if it helps. It has had the low air flow since I bought it with only 20K miles on it.
I had the same issue with my last Chevy Silverado so I just kind of assumed their A/C sucks. Then I found out differently on a truck like mine. Now I
want the higher air flow.
Thanks
Thanks
you guys were right. Wow, what a blocked couple of filters. Now I can freeze myself out. Thanks for the help. You wouldn't believe how many of us didn't know there was a filter in there.
if you deal with alot of dirt where you drive you better leave them in, otherwise you'll have to figure out how to clean the evaporator, its just best to replace them, not to leave them all the way out, i just had the hvac out of a mid 90's chev and it was so plugged i had to replace the evaporator and the heater core. then i blocked off the clean air door and mounted a cabin filter at the bottom of the recirc air supply, the temp coming out of the vents was 36 degrees and i dont have to worry about doing it again, but this was on a kodiak grain truck and everything gets full of dirt so i was left with no choice
chevykid06
Silverado & Fullsize Pick-ups
January 6th, 2007 3:50 AM
