Master Cylinder Drip
I have a 96 I/2 ton with a pesky brake master cyl. weep. It weeps around the pry-off plastic top and around the foam seals where it "plugs" into the metal part of the m/c. I have replaced the whole assy. 3 times and after about 3 months they all start to wep in the same places...Is there a older all metal version of this m/c with the metal top that has the bail wire retainer that will work. I'm tired of buying these plastic resivior m/c's. 1 oem new and 2 reman's and they all leak...not one of GM's better ideas.
Regards
Regards
i'll ask some old timers at work who may have seen this. I never have as its before my time...18 year old relics...the guys who cut there teeth on these are all retired. you done all the right things..replacing the whole assembly.
