moisture in distributer - Chevrolet Forum - Chevy Enthusiasts Forums
981500k's Avatar
hutchinson mn
September 27th, 2010, 9:28 PM   #1
Hi I have a 98 K1500 350 Vortec and when it rains and the morning dew The cap collects moisture and need to know how to prevent this as Ive done it all so far, changed the dist, cap, rotor, wires plugs, all and im at my wits end with it whats the recomended solution or trick. Thanks Brad
tinbender59's Avatar
September 27th, 2010, 10:29 PM   #2
Posted By: 981500k Hi I have a 98 K1500 350 Vortec and when it rains and the morning dew The cap collects moisture and need to know how to prevent this as Ive done it all so far, changed the dist, cap, rotor, wires plugs, all and im at my wits end with it whats the recomended solution or trick. Thanks Brad
what I do Is to fill the screen in the bottom of the distributor with sealler, and stop the madness, kind of a BS idea any way!!! put a vent in the bottom??? gm sure listened to ford on that one
981500k's Avatar
hutchinson mn
September 28th, 2010, 8:01 PM   #3
Ok not to say your wrong but I was told not to close them off because then it woudnt vent properly but I never dealt with this before and its about to **** me off because Ive dumped tons into this truck for it to be something stupid make me get rid of it. If pluging them is whats recomended Ill try it.
gfd749's Avatar
September 29th, 2010, 12:58 AM   #4
if the moisture is causing your truck to miss one thing you can do is spray a thin coat of cooper seal inside your distributor cap. when i was told about it i didnt think it would work but it stopped mine from missing.
Tags
Sponsors
