My truck feels sluggish. Help - Chevrolet Forum - Chevy Enthusiasts Forums
Hick727's Avatar
July 23rd, 2010, 11:41 PM   #1
Im getting a 1995 Chevy K1500 Z71 with a V6. Its Automatic. Its a Short Box. When we test drove it it felt sluggish. It would get up to speed but it took a while longer then usual. What could the problem be if there is even one? I think its because its a big truck with a small engine.
therewolf's Avatar
July 24th, 2010, 12:45 AM   #2
Hi Hick727,
Welcome to the Chevy Forums.
Okay, the little bells in the back of my head are going DING,DING,DING! A Z71 with a V6 isn't unheard of, but do yourself a favor, and pop open the glovebox, and look at the Service Parts Identification sticker. The RPO codes you're looking for are Z71(Chassis package: Offroad) , and G80(Limited Slip Differential)[READ-POSI REAR]. Anybody can slap a pair of Z71 decals on the fenders. Now, is it 2WD or 4WD? This may affect your bargaining posture if it is not actually a Z71. Is it a private sale, or a car lot?
Three things which come to mind are the gas filter, air filter, and the transmission filter. I would change them all as a matter of course when picking up a used vehicle.
While it may have a lot less top end, and certainly won't be able to tow as well as a V8, it shouldn't be "sluggish" off the line. Perhaps you are accustomed to driving pickups with large V8s?
Hick727's Avatar
July 24th, 2010, 1:15 AM   #3
Its both 2WD and 4WD. I believe its a true Z71. Its a private sale. I think im gonna change all three of those things and the oil and the transmission fluid all right away.
Hick727's Avatar
July 24th, 2010, 1:24 AM   #4
This is the truck
Blindsight's Avatar
Clemson, SC
July 24th, 2010, 2:39 AM   #5
I'd advise you run some seafoam through it (all 3 ways), then do a full tune-up on it. That's a pretty good looking truck; nice find. Perfect candidate for a 6.0 swap ;-].
therewolf's Avatar
July 24th, 2010, 7:40 AM   #6
It does have Z71 rims.
Keep us posted how it works out.
Hick727's Avatar
July 24th, 2010, 9:54 AM   #7
Posted By: Blindsight I'd advise you run some seafoam through it (all 3 ways), then do a full tune-up on it. That's a pretty good looking truck; nice find. Perfect candidate for a 6.0 swap ;-].
what do you mean all 3 ways?
s34n's Avatar
sacramento,ca
July 24th, 2010, 11:02 AM   #8
i know 2 ways. put a can in the gas tank and run a can through your intake. im not sure about the 3rd way.
Blindsight's Avatar
Clemson, SC
July 24th, 2010, 11:05 AM   #9
There are 3 main ways to use seafoam that will help clean your engine out and possibly (and probably) give you some performance back. All 3 are outlined on the back of the can.
The ways are:
In the crank case (in the oil, use for about 500 miles then change the oil)
Through a vacuum line that goes straight into the intake manifold. (Typically through a brake booster or pcv valve)
In your gas tank.
As I mentioned, all of these uses are outlined on the back of the can with pretty detailed instructions. Seafoam is a fantastic product.
s34n's Avatar
sacramento,ca
July 24th, 2010, 5:10 PM   #10
x2 with blindsight
Tags
Sponsors
