blown cat
blown cat
I recently installed new headers on my truck and surprise, surprise, one of my catalytic converters got blown out. However, I was thinking about gutting the cats anyways, so is there anyway I can gut the cats and keep the rear O2 sensors from tripping the check engine light? I think my truck is due for inspection in the spring. It's a 98 5.7L silverado.
Thanks,
Austin
Thanks,
Austin
I was also thinking about getting a tune done by blackbear. I thought I heard that getting a chip or programmer can compensate for the codes that the O2 sensors might throw after doing something like this. So I was wondering if anyone knew if a blackbear tune could do this? Or am I just completely off my rocker here?
yes im sure blackbear could do this, i have never used them,but if it is a custom tune they will make it work, but till then your truck could go lean so watch the temp
Keeping an eye on the temp might be a little difficult right now though... One of the guys helping me intstall the headers accidentally broke my temp sensor. So I bought a new one, but now the temp guage skyrockets to 260 degrees within a couple minutes of turning the truck on. Speaking of which... anyone know what might be wrong there? I've been asking around, but no one knows why it might be doing that. It's been that way for a few weeks now and it hasn't blown up yet
you proably have an air pocket on top of th motor, right under the thermostat. These new GM's are bad about that, the water does not get to the thermostat so it never opens. an old hotrod trick that I was taught 20 years ago, is to drill 3 1/8 inch holes in the outer ring next to the formed hole of the thermostat. I will try to remember to post a picture later that will let you fill the block completely up pearge all of the air into the radiator, plus give you a small flow past the thermostat to ensure It sees the hot water! hope this helps P.S. I do this on every thermostat that I install.
ericnottelin
Silverado & Fullsize Pick-ups
July 2nd, 2012 10:03 PM
