no brake lights
no brake lights
any help no brake lights on my 06 silverado bulbs -good.fuses- good power from the cab to the junction block-good power out of the junction block good, plug everything in- no good,good continuity on the harness to left and right lights--- stumped thanks greg
been checking that,continuity in the left and right harnesses is good, have power to the junction block into and out to the left and right but nothing when I plug those harneses in at the stop lights,bulbs are good very weird thanks
Hmm, you keep saying good power into and out of the junction block. Are you reading good voltage at the bulb socket with the brake pedal depressed and none without? Is that with or without the parking lamps on? To be clear, the stop lamp bulbs usually have two filaments, one for the stop lamp and the other, parking lamp.
brake lights
no I have power out of the junction block but none at the socket for the brake light all other lights work fineso I guess nothing between the socket and the junction block,thanks greg
So, you either have to repair the wiring or splice in a new socket, depending. The only thing I can add is to make sure to seal the splices good (with solder and heat shrink tubing if you can). Good luck.
brk lites
thanks gonna tear out the harness 2 morrow all the grounds look good - gonna try to jump wire and see if I can locate something that way as well, thanks again -greg
TRUCKDIVA
July 22nd, 2013 6:48 AM
DOBERDEWD
December 11th, 2011 11:35 PM
skdevore
August 26th, 2009 10:18 PM
cowboys
December 18th, 2006 12:28 AM
