Notices
No codes?
Old January 16th, 2012, 9:36 PM
Cpollock's Avatar
Default No codes?
On my 1996 Chevy k1500 the engine light is on. But when we hooked up a diagnostic check, it didnt come up with any codes, the truck does not run at all at the moment. What could be the problem?
Old January 18th, 2012, 11:41 AM
slw210's Avatar
Do you have fuel and spark?
Old January 18th, 2012, 7:04 PM
Cpollock's Avatar
Ya but i'm not sure what the fuel pressure is. I gotta put the pressure tester on and see what she says. It now shows codes and it says oxygen sensor, oxygen sensor heater, comp *inset 2nd word here*, and what not. It is very confusing.
Old January 18th, 2012, 7:46 PM
02 codes won't cause a no start as the ecm doesn't use oxygen sensor data for starting.
Old January 18th, 2012, 9:44 PM
Jeffstang's Avatar
are the codes may be pending? I know if you dont drive it through its cycle the codes will not come on, Sounds stupid but either clear it by a reader or unhook your battery to reset the light. -on second look i didnt read it wasnt running, not too sure there but check suck, bang, blow
Old January 19th, 2012, 10:35 AM
slw210's Avatar
Do you have compression? Does it try to start? Are all components spinning when you try to start?
rabbit0102030
S10 & Blazer DIY and Useful Threads
March 5th, 2014 7:36 PM
mrgoalie
September 22nd, 2006 5:05 PM
Nels
August 26th, 2006 2:22 PM
slingblade
June 8th, 2006 2:57 PM
carplex2
June 7th, 2006 5:45 PM
Quick Reply: No codes?
