offset rim help?!
offset rim help?!
i've got an '84 chev k20 that i want to put a 6 in lift on with 35 in tires. wondering about offset? what should i get/ look for? does it matter the offset? does it hurt anything if I use the wrong ones? advise?
If the truck has even a decent paint job i wouldnt push them out past the fenders the older trucks can sling mud and rocks anywhere on it roof hood in the windows nothing is safe. and if you deal with snow or narrow roads the offsets also suck in snow you get pulled everywhere because you dont match up with anyone elses tracks and the roads i hunt on you cant get much more then a full sized stock truck trough. But if you dont care about paint and you doalot of highway driving the offsets are nice it makes the wheel base wider which means more stable. and more often then not pushing them out a bit makes them look better then a normal offset. more beefy instead of a been stock
bruisr
Silverado & Fullsize Pick-ups
September 11th, 2012 9:08 PM
