Notices
Oil Pressure Low
Old June 19th, 2013, 12:11 PM
crazypatey's Avatar
Default Oil Pressure Low
Hello, i have a 95 chevy k1500 z71 5.7L. The truck has no knocking or oil leaks and is full of oil but when at idle after running for awhile the oil pressure gauge goes very low, but when first started in the mornings or after a while of being off the oil pressure is normal, what could this be?!?!?! Really need help!!!
Old June 20th, 2013, 2:09 PM
Poncho_villa's Avatar
I had a '94 Suburban with that same engine and had the same symptoms. It eventually spun a connecting rod bearing and I believe a bad bearing was the reason for the low oil pressure. I hope your situation is different.
Old June 20th, 2013, 4:41 PM
samsaridinc1500's Avatar
I used to have a problem like this, it was an '87 s10 but may be an issue almost the same. The oil cap was just old and wouldn't fit right. I bought a replacement and topped off the oil, never had a problem again. It may be something else but that might be something just to check.
Old August 9th, 2013, 3:36 PM
mikebruce700000's Avatar
Did you ever get your oil pressure problem fixed?
usernamehere
August 2nd, 2021 12:07 PM
Eric Sherden
September 24th, 2013 1:21 PM
not_a_car_dude
September 15th, 2013 7:41 PM
MikeShirk
December 31st, 2012 10:39 AM
larry_chip
April 24th, 2007 11:46 AM
Quick Reply: Oil Pressure Low
