Oxygen sensor DTC P0036 will not go away.
The problem may not be the Heated O2 sensor, it could be the wiring or even something else upstream of the sensor.
The code is the symptom the computer sees but not necessarily the actual cause...
I'd check the wiring and the connector to the sensor, it might be worth checking all fuses as well...
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> Now I`m getting P0036, P0054 and P0141
At idle HO2S12 = 440-600mv
HO2S22 = 195 -180mv
HO2S22 = 195 -180mv
