P0327 knock sensor
P0327 knock sensor
2002 4.3 v6 Silverado, does anyone have the electrical schematic for a 2 wire knock sensor? I pinched the wiring harness replacing the clutch.
I found the blue wire went to #11 at the PCM, the other wire is gray, I'm assuming its 5vdc reference, but I'm not sure. I need the pin number at the pcm. I ran it to ground but still get P0327, I dont want to connect it to 5vdc and take out the pcm, unless I'm sure. <O</O
desilverado
Silverado & Fullsize Pick-ups
March 24th, 2007 4:10 AM
