Plug wires
Plug wires
Moving up the line to resolve a cold start/misfire problem. Is the quality of the aftermarket products as good or better than oem ? Advertising is just that. Experience is priceless. Anyone want to share some of the later ?
RE: Plug wires
Thanks.
Accell and NAPA are old friends. MSD and Taylor have never made under the hood for me. No particular reason other than just not being readily available locally. I'm looking for a fix to a cold start problem. Enginestarts well and will run good for about 30 seconds or until the idle begins to drop below 1000. Then begins tomiss, sometimes it quits completely, not always. As the engine warmsit begins to smooth out and run fine. This only happens at about 30 degrees or less. So far I've replaced the plugs and added lots of injector cleaner to the fuel. Results : No improvement.
RE: Plug wires
Run Lucas Upper lubraction/fuel injection system cleaner. Then run sea foam through the brake booster vaccuum and clean out the throttle body with some throttle body cleaner. That should help a lot.
chevykid06
Silverado & Fullsize Pick-ups
December 28th, 2006 10:43 PM
