Notices
Sponsored by: DashLynx
Propane/Gas question..
Old June 6th, 2012, 11:21 PM
ihavenoname's Avatar
Default Propane/Gas question..
Hey, I have a 1983 Scottsdale. The engine was originally on gas, but had been rebuilt, and changed to propane. I've been considering changing it, so it does both gasoline, and propane. I know that in the past they had problems with that. (Timing, fuel/air ratio? etc.)
I was wondering if anybody knew of any new technology out there that could retune the engine everytime it got switched over from propane to gas....
Old June 7th, 2012, 3:18 AM
Former Sponsor
johntaps's Avatar
Post Propane/Gas question..
First of all Welcome to the Forum
As you know that the Propane has much higher octane number than Gasoline so it requires very low flash temp. So it is not possible for you to change the ignition timing every time when you switched from gas to propane.
Hope somebody else will throw light on this....
Old June 7th, 2012, 5:04 AM
Allan In NE's Avatar
No, you don't need to "re-tune"; just set the engine up to factory specs and change fuels at will.
Only problem I've ever ran into with these setups is the outside temps. At -20 to -30°, the propane just does not flow/vaporize as well as gasoline.
Allan
ahearnm
March 19th, 2023 6:37 PM
Dino620
May 23rd, 2014 1:54 PM
Panefull
April 28th, 2013 8:55 PM
olemattinson
K5 Blazer
December 3rd, 2012 11:41 AM
Billybobjoe12323
September 21st, 2011 9:53 AM
Quick Reply: Propane/Gas question..
