random misfire???
random misfire???
I usually don't post to forums because I can usually find a problem close to mine but this is a mystery. I have 1997 k1500 pickup it has 240,000 miles on it. no check engine light but I can pull a code of p0300 (random misfire). there's no specific time that it does it. the random misfire comes and goes no real pattern to it. things ive replaced: fuel pump, fuel filter, egr valve, ignition coil, camshaft position sensor, rotor, dist. cap, wires, spark plugs, and a brand new intake system from Volant. any suggestions?
i have 98 1500 and was having the same problem.. i did the same exact things as you minus a few things but i tweaked the timing on it just a lil bit and that seemed to have solved my problem
02HEAVYDUTY
Silverado & Fullsize Pick-ups
November 19th, 2007 4:41 PM
