Notices
Sponsored by: DashLynx
rear tailgate spoiler help
Old July 26th, 2009, 9:36 PM
madmaxx1's Avatar
Default rear tailgate spoiler help
Hi guys!
I have a easy question about the four hexagon "nut" inserts for the rear spoiler on the tailgates. How do I get the long insert nuts to tighten up against the tailgate so when I put the screws in the spoiler is tight and will not pull the nut inserts out?
Thanks
Old July 27th, 2009, 8:06 AM
old dog's Avatar
Default nut's
i assume you are putting the spoiler type cap on to replace the smooth one . the nut's get compressed into the sheet metal with a special tool for nut zirt's .i did the same thing on my 2500 hd because the gate is heavy to lift up ,and the spoiler gives some thing to hang on to .i had to make a special small metric insert mandrel for the installing tool .you may have to go to a dealer ship or body shop that has the tool .
Old July 28th, 2009, 3:26 PM
charlie pachanga's Avatar
I use a nut just larger that the nut sert threads (GM nut serts = 6mm), I think I use a 8mm (that way 8mm bolt spins freely inside on nut sert), I also cut a few grooves on the bottom of nut making contact to nutsert so it bites on nutsert. Make sure you use at least 2 maybe 3 washers between the bolt and the 8mm nut.
You would then need a wrench to hold the nut you cut the grooves in and a 13mm wrench/ratchet for the bolt (use a different bolt and not the torx 30 that holds the spoiler down). I use a cordless impact and a wrench.
Last edited by charlie pachanga; July 29th, 2009 at 8:17 PM. Reason: Sorry wrong size for nutsert
cshaw1
Avalanche
March 30th, 2015 2:51 AM
lt1george
December 12th, 2011 1:03 AM
GREGSHHR
HHR
May 31st, 2010 10:06 AM
dennisb1264
January 21st, 2009 1:54 AM
groundupkustoms
January 22nd, 2008 11:00 PM
Quick Reply: rear tailgate spoiler help
