Last edit by: IB Advertising
Browse all: Wheels and Tires
- Chevrolet Silverado GMT800, GMT900, K2XX How to Replace Wheel Bearings
Step by step instructions for do-it-yourself repairs.
rear wheel bearing.
#12
yeah make sure you put the pin back in a finger tight the 8mm bolt once you pull the axles out and b4 you do anything else. it will save you plenty of time trust me. I didn't the first time I did this and the spider gears fell out.
#13
You have an 8.5 rear end which is a c-clip. If you pick up the puller set I recommended (excellent quality and will last a life time) you will find replacing the bearings a snap. I have done 6 of these and have never not had the bearings come out after several hard slams with the slide hammer. If they just will not come out.....heat the outside of the axle tube they will come out. Good luck.
sinnersmc
March 8th, 2013 12:09 PM
rosencra38
March 22nd, 2012 2:40 PM
Ronnie-J
Express & G-Series Vans
September 6th, 2010 11:50 AM
