Notices
Reverse Lights not working
Old October 22nd, 2011, 8:01 AM
Huntnm4ck's Avatar
Default Reverse Lights not working
What are the first places I should check to see why my reverse lights don't work on my 88 Silverado. I have checked the fuse panel under the dash and all looks good there. I have pulled the lense cover and bulb looks good. The lights have never worked on this truck since I bought it 9 years ago. Don't drive it much at night so haven't worried about it much, but I want to get them fixed. Is there a spot on the trans that needs to be checked?
Old October 22nd, 2011, 8:31 AM
maxxman04's Avatar
on a stick shift, there is a backup switch on trans, usually drivers side at tail end of trans. on an automatic, the switch is at base of steering column, not a typical looking switch. here are a couple generic pics. the first is a fairly typical in trans switch, the second is steering column mounted.
Attached Thumbnails Reverse Lights not working-ph-reverse.jpg   Reverse Lights not working-neutral.jpg
Old October 23rd, 2011, 11:38 AM
OLD WRENCH's Avatar
When you say the lights have never worked I woud make sure the bed is grounded to the frame. Add a ground wire if in doubt.
Old October 23rd, 2011, 12:36 PM
kevinkpk's Avatar
If fuse is good, and bulbs are good. I'd suggest take the bulbs out of the socket, and check for corrosion.
Old October 23rd, 2011, 5:41 PM
Huntnm4ck's Avatar
wouldn't that not let any of the lights work if the ground was broke and not just the reverse lights?
Old October 24th, 2011, 5:15 AM
OLD WRENCH's Avatar
You said "the lights" not back up lights,guess I took it to mean all of them.Your refund check is in the mail.
Old October 24th, 2011, 9:17 AM
Huntnm4ck's Avatar
not a problem. How much do I get? LOL!!
Old October 24th, 2011, 9:22 PM
OLD WRENCH's Avatar
Everything you have paid to date.
Akimball88
April 11th, 2020 9:34 PM
swatson1
February 26th, 2017 8:25 PM
95chevyTN
February 3rd, 2014 8:46 PM
slihp
Express & G-Series Vans
11
August 16th, 2012 2:56 AM
skdevore
August 26th, 2009 10:18 PM
Quick Reply: Reverse Lights not working
