Notices
Old August 10th, 2015, 12:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
service airbag light
Old March 18th, 2008, 11:21 PM
zkgraves's Avatar
Default service airbag light
yeah , getting this service airbag light.. ive never been in a wreck and i tried resetting the computer (unhooking the battery) and i still get it... anythoughts?
Old March 18th, 2008, 11:35 PM
Dougleo's Avatar
Default RE: service airbag light
See if you can find someone with a scan tool capable of reading the SIR system. Get a code and go from there. Someone on here'll help you out. What year/make/model of truck?
Old March 18th, 2008, 11:37 PM
zkgraves's Avatar
06 chevy silverado 2 wd single cab
Old March 19th, 2008, 8:45 PM
Dougleo's Avatar
Does this help at all? If not, get it scanned and get the code out of it and go from there.
Some owners may comment of a SIR MIL and if equipped the temperature/compass display on the inside rearview mirror is inoperative. This concern may be caused by the 15 Amp Air Bag Fuse open. Reports from the field have shown in some cases circuit 1139 Yellow may be shorted to ground at the Left I/P Junction Block mounting bracket as shown below.
Recommendation/Instructions:
To correct the concern repair the wiring as necessary and insulate harness and mounting bracket with foam tape to prevent a reoccurrences
Old March 19th, 2008, 11:25 PM
TransAm Man's Avatar
Yah, get someone who has a scan tool and get them to clear the fault code for the airbags
Old March 20th, 2008, 6:11 PM
zkgraves's Avatar
i pulled the fuse it and it was fine and when i put it back in it worked.. weird..
Old March 22nd, 2008, 9:42 PM
Dougleo's Avatar
Just an intermittant thing then. I've seen loose connections at the inflator in the steering wheel.
Old September 22nd, 2010, 9:44 AM
asutton1@daltonstate.edu's Avatar
Default 06 silverado truck
So the fact that my service airbag light is showing up is bc of a short under my hood? or do i just need to take it to a mechanic
05chevy
October 6th, 2012 7:56 AM
ltzboy
February 20th, 2010 11:08 PM
peduzzi
February 2nd, 2010 2:02 PM
05chevy
September 21st, 2009 9:32 PM
impala2k3
August 10th, 2009 7:55 PM
Quick Reply: service airbag light
