sevice engine code 43
I have a 1993 chevy k1500 pickup with a auto tranny 4l60e and a 350 motor. I read the codes with my paper clip and I am reading error code 43. I tried fininding info online but not really finding any helpful info can any one help me out here. I think it is an electronic sensor (which i hope because i am an electrician) but I just dont know yet. Anyone???
-43 One or both of the knock sensors were either open or grounded for 5 seconds. VIN P
-43 Knock sensor voltage was either above 3.62 volts or below 1.44 volts for 24 seconds or ECM did not receive the knock sensor signal. VIN J
Looking around for you those are the two things I found for code 43 for a GM 5.7 Liter depending on what your VIN starts with. I would go ahead and check out your knock sensors. I don't want to post links to other forums but google "where is my knock sensor located 93 chevy 5.7" and the first result should be of help. Hope this helps
Vinna
Express & G-Series Vans
November 12th, 2012 8:51 AM
