should a torque converter rattle when tipped side to side?
I dropped the 4L60E tranny from my 1994 C1500 because it was slipping all over the place in 3rd and 4th. I noticed after I removed the TC that if I held it level and tipped it side to side that it sounded/felt like something was sliding around inside. I looked inside where it connects to the input shaft and noticed that the part that connects to the shaft was the part moving. It seemed to move about 1/4 inch in every direction. If I mount the TC to the tranny and rotate it by hand it seems to operate normally. No grinding, rattling, scraping, etc, sounds.
Is this normal or is the TC bad? When I drained the tranny there was no chunks or large pieces of metal but the fluid was burnt to a crisp.
I have a used replacement tranny to put in (out of a camaro). My real questions is is the TC bad or is it normal to have some movement on the inside? I dont want to put it back together and waste my ATF if I just have to remove it all again to replace the TC.
TYVM all. In case you cant tell I am new to all this and I just bought the truck this week so the tranny issues aren't my fault lol.
Thanks again all.
Thanks again all.
replace it. It will be full of friction material from the slipping clutch packs. You can't clean it out of the t/c. Definitely Back flush your trans lines and cooler. If you don't, you will destroy the replacement trans.
JustinL
Silverado & Fullsize Pick-ups
August 23rd, 2014 12:54 PM
mikeryan
October 8th, 2007 8:26 AM
ChevyMechaniac
September 12th, 2006 2:38 PM
