silverado dies out while driving??? - Chevrolet Forum - Chevy Enthusiasts Forums
Go Back   > >
Log In
LinkBack Thread Tools Search this Thread
Old 11-29-2010, 02:37 AM
Default silverado dies out while driving???
i have an 06 chevy silverado and while driving my truck just shut off and then it takes about 2 to 3 cranks for it to start back up. then it will run okay for 2 days then do the same thing.. please help.
Old 11-29-2010, 05:40 PM
Something like this can be a bear to find. I would start with the fuel filt if it hasnt been changed in a while. Pull it off and try to blow thru it there should be very little resistance.
Old 11-29-2010, 10:59 PM
thanks for the advice already changed the fuel filter. any other suggestions.
Old 11-30-2010, 12:29 AM
Then I would check the fuel pressure.
Old 11-30-2010, 08:10 AM
Check the fuel canister. This is in the back by the fuel tank. It grabs the overflow.
I just had to replace one on a 08. It will cause problems with fuel flow and it musts be changed.
Old 11-30-2010, 01:02 PM
could be your fuel pump going out
Old 12-01-2010, 11:27 AM
thanks for all the advice but i already change my fuel pump and the canister and the fuel pressure is fine. any other suggestions?
Old 12-02-2010, 07:33 AM
How about electrical? Or Maybe there is a problem with the mapping (Maybe Timing is off a bit)? Have you checked any codes?
Old 12-02-2010, 09:17 AM
inspect all your plug wires and spark plugs, and yeah defidently check for codes
Old 12-03-2010, 10:31 AM
checked the codes and all it is, is a bad cat converter but i doubt that would cause a stall.
Thread Thread Starter Forum Replies Last Post
Still working on a 2004 malibu dies while driving icemanthe1 Malibu 0 10-03-2012 04:45 PM
92 Silverado dies while driving OkieChevy Silverado & Fullsize Pick-ups 7 07-12-2012 06:42 AM
2000 Malibu Dies while Driving littlemama Malibu 0 02-06-2012 07:53 PM
Impala dies while driving pauldkreutzer Impala 1 10-21-2010 09:09 AM
2000 malibu dies while driving sammartin1980 Malibu 1 07-11-2009 10:47 AM
Tags
01, 03, 08, 1997, 97, chevrolet, chevy, ck, cuts, died, dies, driving, engine, running, shut, silverado, stalls, stops
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
