Notices
Old July 22nd, 2015, 10:16 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
Stainless steel braid brake lines
Old September 4th, 2012, 9:57 PM
ukrkoz's Avatar
Default Stainless steel braid brake lines
Hi all
Can anyone confirm those do really help?
1999-2004 Chevy Silverado Brake Lines - Russell 672430 - Russell Brake Lines
Or similar in strength and resilience to internal pressure
Old September 4th, 2012, 11:12 PM
jesse06's Avatar
regular ol' rubber never done me wrong, but then again im not race car driving
Old September 5th, 2012, 10:00 AM
country_09's Avatar
They hold up better over time is all I've noticed from seein them on peoples trucks. No difference in stopping power from em
Old September 5th, 2012, 10:14 AM
ukrkoz's Avatar
So, how do we fix stopping power?
Old September 5th, 2012, 11:36 AM
shamrock246's Avatar
I've read about upgrading it to the NBS master cylinder (2001) plus line adapter helps thats what im going to try as soon as boating season is over,im probably going to upgrade the brake lines due to the milage
Old September 5th, 2012, 4:18 PM
grumpychevy's Avatar
Better stopping power... Larger diameter rotor + more pistons in the calipers. The more surface you can have touching the brake pads evenly will greatly improve stopping power. This get expensive tho so other options would be drilled and slotted rotors with high performance brake pads. If you run stock brakes then there is no need for stainless braided hoses.
Old September 5th, 2012, 6:29 PM
country_09's Avatar
^ exactly. Bigger rotors/dual pistons/and larger pads. I upgraded my 01 silverado with 12" rotors and dual piston calipers up front to the 06 z71 4x4 13" front brakes/calipers/rotors for 300. Also upgraded the back from 12" single pistons to the 06 z71 Tahoe 13" rotors/brakes/calipers for 300 as well. Costs money, but I can stop 35s without a worry in the world!
Old September 5th, 2012, 9:06 PM
ukrkoz's Avatar
Fait enough.
Does it mean, I also have to upgrade rims to larger inner diameter? As larger rotor should off set caliper out farther...
Old September 6th, 2012, 7:26 AM
Possibly depending on clearance.
Old September 6th, 2012, 8:17 AM
What size wheels are on the truck? How large are the rotors? How much larger do you want to get? Your clearance issues are going to be with the caliper more than the rotors so if you go aftermarket they should give you a minimum diameter wheel to use. If you go factory upgrade like country then you will need a minimum of what came on the truck you get the parts off of.
Quick Reply: Stainless steel braid brake lines
