Stiff steering after new steering gearbox
Hello,
I had the steering gearbox replaced for a rem one.. Steering was really stiff.. i couldn't turn. Mechanic said that the steering was fine in the beginning but then the steering gearbox locked. i don't even know what that means lol. what could be the problem ? The steering pump is new.
Can a bad steering gearbox cause stiff steering or it's just air in the system ?
Could it be the hoses letting air back in the system because according to the car mechanic the car ran fine when he tested it.
Could internal components go bad in one day because of air in the system?
car was not driven but engine was started for almost an hour.. and steering wheel was turned left and right few times.. i wanna know if this rem steering gearbox from autozone is functioning well.
Not sure if this will help or not. Check on the steering box to see if there is a screw with a locking nut on it. If there is try loosening the nut and back the screw out about 1/4 turn. Tighten the nut back up while holding the screw so it doesn't tighten when turning the nut and give it a try. I know on my older cars that screw/nut was used to take the slack out of the steering. If it is too tight that might cause stiff steering. Also, with the engine turned off you might try to turn the steering shaft back and forth and listen/feel for too much slack. If it feels sloppy it's too loose. I'm not a mechanic so maybe a real mechanic can give info on this but this is what I used to do on my old cars with regular steering when I was younger. And that was a long time ago...
civilguy2857
Silverado & Fullsize Pick-ups
August 7th, 2015 3:27 PM
scumpoozie
June 15th, 2014 10:38 AM
w002mia
March 18th, 2013 11:42 AM
