Notices
Sponsored by: DashLynx
Stripped sparkplug hole
Old August 14th, 2012, 6:31 PM
starvnmarvin's Avatar
Default Stripped sparkplug hole
I have a 1996 chevy shortbed with a 4.3 vortec and I have a sparkplug that keeps backing out because the hole is stripped. Is there a fix with out replacing the head? maybe some kind of sleeve insert modification? If it would mean replacing the head I would rather replace the engine thus it already has 256,xxx miles.
Old August 14th, 2012, 6:37 PM
old dog's Avatar
Default strioed hole
give these guy]s a try !
++ TIME-SERT SPARK PLUG THREAD REPAIR KITS ++ spark plug thread repair kits for spark plug problems, thread stripped spark plug repairs in damaged threads in spark plug hole stripped out approved thread repair, aluminum head spark plug repair
Old August 14th, 2012, 7:21 PM
spyncycle's Avatar
No matter what you do to fix this, the head has to be removed to do it.
Old August 14th, 2012, 9:37 PM
jesse06's Avatar
not sure if a HeliCoil would work in your situation, sounds like the threads are GONE, so you cant use a thread chaser. might have to take the head off to fix
Old August 14th, 2012, 10:05 PM
Professional Mechanic
MDTAHOE's Avatar
They sell heli coils for spark plugs. You can do it with the head on. 5.4l Fords blow the spark plugs out all the time. They sell a special insert for those (will not work for your application). We drill and tap the hole with the head on all the time. You must set the engine up so both valves are closed, drill it, tap it then blow the metal out out cylinder with an air compressor.
Old August 15th, 2012, 1:38 AM
jesse06's Avatar
so you think the helicoil would work, or you saying it should get the hole bored out and put new threads at the next plug size up?
Old August 15th, 2012, 7:18 AM
MDTAHOE's Avatar
Try the heli coil
Nebulation
February 1st, 2014 6:34 PM
Cretaccir
July 7th, 2013 6:16 PM
Zombie Toes
October 23rd, 2012 3:35 PM
Morten
June 15th, 2012 2:34 AM
eudaman
March 17th, 2007 1:45 AM
Quick Reply: Stripped sparkplug hole
