low oil pressure on rebuild..
just rebuilt 99 silverado 6.0L.. message canter is reading low oil pressure... when removing the motor the oil sending unit was cracked.. I am not sure if that is why I am getting the reading..Pulled off the valve cover then started the motor.. There was a small stream of oil coming out of the push rods at idle.. Never seen a 6.0l before but I am use to the oil shooting all over the place.. Is this normal? I did replace the oil pump during rebuild.. The only code coming up is the 02 sensor..
Thanks
Thanks
Eric Sherden
September 24th, 2013 1:21 PM
not_a_car_dude
September 15th, 2013 7:41 PM
larry_chip
April 24th, 2007 11:46 AM
