Notices
symptoms
Old April 7th, 2009, 9:31 PM
suzuki-guy's Avatar
Default symptoms
what are the symptoms of a bad ignition coil? My truck idles fine, goes down the road fine but when you are in a parking lot or when you slow down from going normal speed for ahile it will bog down like its going to stall but never does!!! Ive done everything, this is the only thing i can think of that i havent replaced!!!
Old April 7th, 2009, 10:04 PM
98white5.0's Avatar
Might have something to do with the cam you have. Probably just a normal function of your cam. I'm assuming it is hotter than a stock cam.
Old April 7th, 2009, 11:07 PM
suzuki-guy's Avatar
yeah but this started doing this two years after the cam was installed beleive me this is not normal my friend. thanks for your input though i appreciate it. does anyone know the symptoms could an ignition coil do this problem stated above? worse comes to worse ill have a brand new accell super coil anyways cant hurt anything
Old April 7th, 2009, 11:16 PM
EvansBlue's Avatar
Possibly... Most of the time with at bad coil, you'll experience an uneven missing.
Old April 7th, 2009, 11:19 PM
98white5.0's Avatar
Does it dip down then jump back up or does it stay there at the low rpm? It if dips and recovers, it might be a vacuum leak. Maybe IAC? I don't think the coil would be the problem but it might. Maybe even check fuel pressure, it might be dippin pretty low at that particular time.
Old April 7th, 2009, 11:24 PM
98white5.0's Avatar
Does a 1995 even have a IAC? I was thinking you had a vortec.
Old April 7th, 2009, 11:27 PM
suzuki-guy's Avatar
yeah it does on the side of the throttle body i replaced it already im telling you ive tried everything... it dips down then recovers I replaced the vaccuum already and my fuel pressure is normal thats why im wondering if its the coil has anybody had a problem similar to this
Old April 7th, 2009, 11:28 PM
Outcastz89's Avatar
1995 was the last year of the older TBI. Then in 1996 they went to vortec. It has a IAC.
Old April 7th, 2009, 11:29 PM
suzuki-guy's Avatar
i dont know if you guys saw my other post but do you have to reset your brainbox when you replace the IACV?
Old April 7th, 2009, 11:41 PM
98white5.0's Avatar
I knew that already. I changed my verb tense in the post you were responding to so it won't be as confusing. I was assuming it was a 1996 or later due to the body styling. I was just asking whether or not a TBI even had a IAC. I remember when the vortec first came out. My dad was one of the first in line to get one. I remember compared to our 1994, it was a monster. We thought we were the ****. Whoopin the dodges and smokin those 80's camaros. It seemed like a sports car at the time.
Quick Reply: symptoms
