symptoms
#21
I don't think the pressure is very high on TBI. The vortecs use like 60psi but I'm thinking TBI is like half that or even less than that. A o-ring kit from the parts store might be the thing to get. Still not sure what type of o-ring it is, been too long.
#22
Ride of the Month
May 2009
Ride of the Month
May 2009
I think the pressure is between 12 or 13 psi, don't think there is an o-ring at the connection, it's more like a ANSI fitting or seated flare.
#25
no i just replaced it with a MSD coil. it wa sonly 40 bucks at autozone and i just looked in my haynes and it does have orings thanks for your help guys
#26
Bogs down,
You might think this is off the wall but the details of this thread are interesting . So, when you slow down it bogs down. Take it a step further, when you apply the brakes or just coasting. If it bogs when you apply brakes, possibly you have a problem with the booster pulling to much vacuum and the engine is not recovering causing it to bog down.
#27
Yeah that was one that I wanted to try but how do I test it? Not something easy and cheap that I could just replace you know? I hear know hissing up front like there is a leak when I press my brake peddle down at idke and then relase it as it is releasing the idle jumps a little but nothing major.
#29
I had the hose unplugged and hooke to a vacuum gauge and the problem was still there would'nt this be the same thing? Thanks' guys for ideas it really helps
tom5170
Silverado & Fullsize Pick-ups
March 30th, 2010 1:51 PM
rossww
September 10th, 2009 10:21 PM
