newbie needs help
newbie needs help
I have a 91 k1500 with a 350. The truck drives great but will not idle good, especially under a load. I have a scanner and watch the iac just keep dropping. I have replaced it and still have the same problem. So after some tinkering I found if I unplug the coolant temp sensor it idles fine. So I replaced it and still the same. So is my problem there or is it the ecm. If it is the ecm do I need a new prom or can I use the old one.
sqhurt
November 29th, 2008 5:56 PM
revamped
August 24th, 2008 10:48 PM
revamped
Silverado & Fullsize Pick-ups
January 23rd, 2008 4:03 PM
