Trailer lights
Trailer lights
Bought a new 2008 Chevy Silverado. I finally got to hook up the bass boat and go fishing. Did the usal thing of getting up before the chickens to head out. It is very dark outside. I cranked the truck up. The truck lights came on. I then noticed my trailer lights weren't working. I turned on the turn signals. The truck signals worked and so did the trailer. I stepped on the brake lights. The brake lights on my truck worked and so did the trailer. When I turned off the turn signals or footmy foot off of the brake, the lights on the trailer went off. I have two boats, so I hooked up the trailer lights to it. It does the same thing.
It's like the truck lighting system is not recognzing that the lights to the trailer need to be on continuosly.It's working like it would if it was daylight outside with only the brake lights and signals visible when you use them.
This is also strange. I looked at the fuse box under the hood, There is a Daytime Running Lamp and a Daytime Running Lamp 2 slot in the fuse box. There are no fuses in them and don't even appear to have any electrical terminals connections in those slots. Is that right???
Yes, this truck is certainly under warranty. If I don't get my trailer lights fixedthrough reader's advice, I'll take it to my dealer.
Thanks in advance,
Rayzor
Thanks in advance,
Rayzor
RE: Trailer lights
curious...if it was dark outside did you actually turn your lights on.....the truck lights will come on automatically, like they are supposed to do, but the trailer lights wont, they are not on a sensor like the truck lights....not sure on this one but chekc it out..
intheknow
July 24th, 2014 10:38 AM
TRUCKDIVA
July 22nd, 2013 6:48 AM
DOBERDEWD
December 11th, 2011 11:35 PM
skdevore
August 26th, 2009 10:18 PM
