Keyless entry
Keyless entry
Hello All. Just found this forum and it is a wealth of info. I just purchased a 2008 Silverado WT with power locks. I assumed it had keyless entry, but it did not. Can the dealer retrofit keyless entry?
RE: Keyless entry
I also have an 08 WT with power locks and I asked my dealer if they could put the keyless on there when I got it and they said that the WT isn't programmable for it, but you can go get an aftermarket keyless or security system and it will work.....that's what I did.
RE: Keyless entry
It's a CrimeStopper brand security system, I'm pretty sure it's a 2000 series. I am very pleased with it, you can set it to different sesitivities for your personal liking and can be so sensitive that if someone gets within a few inches of the vehicle it will go off. It cost me about $300. If you want just the keyless entry though it will probably cost about $150ish.
RE: Keyless entry
Some vehicles can of the assembly plant with out the Reciever it needs to make GM OE keyless work. They all have a reciever even the entry level (non power lock/windows). The reciever is for the Tire pressure monitors (government mandated). You can add a aftermarket keyless or alarm upgrade. If you want more info pm or email and I will give you more info.
