Notices
Sponsored by: DashLynx
Old July 28th, 2015, 3:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Truck will not start when raining or very humid
Old January 1st, 2015, 10:21 PM
  #11
budman283's Avatar
One of the other replies said to try wd-40 inside the cap. My brother-in-law has the same problem and we are going to try that. Get tired of dealing with this at many different mechanic shops and dealers. They may never have tried WD-40. I do remember Honda Civics having that same problem in the 80s and CRC worked then. My Impala also had the problem and CRC also worked in it.
Old June 4th, 2015, 8:55 PM
  #12
jacquiecancer72's Avatar
Default Won't start after rain!
Hey budman283, What happened when you tried the wd40? Did it work? I too am having this same problem & lookin for the solution. I've replaced the fuel pump, & that wasn't the problem. Please help me w/your solution. Thanks.
Old June 16th, 2015, 9:13 PM
  #13
Sapper 22's Avatar
Originally Posted by gfd749
first off, i would like to thank u for what u and your fellow soldiers do for all of us. secondly, i dont know how much help i can give u but maybe i can give u some ideas. have u checked your distributor cap or rotory button. i have had the problem with moisture getting under the distributor cap causing the 4.3 to MISS but i havent had or heard about the moisture causing it not to run. your distributor itself could be a little worn out. but before jumping into changing a distriubtor. try changing your distributor cap and rotory button and spray a thin coat of copper seal under your cap. the copper seal stopped mine from missing when it rained.
gfd749 thanks for the tip! you said to spray copper under the cap, did you mean on the base or inside the cap (on electrodes)?
Old January 15th, 2016, 12:26 AM
  #14
luckywrench's Avatar
Default truck won't start when raining
I had same issue with rain. Pulled off cap n rotor then used a hair dryer to blow off moisture for about 2 - 3 minutes. I also scraped off deposit on cap contact points and it started right up. Replace your cap n rotor with oem product.
Old July 8th, 2017, 10:29 AM
  #15
chev blazerLT 2000's Avatar
Everything you listed is the problem I have with my 2000 Blazer. How did you finally resolve the problem?
Thanks
Old July 8th, 2017, 2:05 PM
  #16
Default Applied fix
I had the same issue when it rained. Moisture was getting into the distributor cap. Replaced it and it solved my issue. The WD40 trick (as mentioned in another pist) makes sense because NASA made that formula to displace water.
Old July 13th, 2017, 3:36 PM
  #17
Shelle Moran Kracht's Avatar
Have you had a chance to check this out yet? Have a 2000 Chevy ZR2 and experiencing the same issues when there is rain or a lot of humidity.
Old July 13th, 2017, 3:37 PM
  #18
Thanks
Old February 1st, 2023, 12:23 PM
  #19
b1gmcdaddy's Avatar
Default Where are the results
What are the
suggested fixes see questions no answers or results
pat l
February 23rd, 2021 10:29 AM
Goody02
June 22nd, 2014 8:28 AM
shaydakiss23
June 9th, 2009 10:45 AM
brewdog
August 26th, 2008 10:03 AM
leapfrog2
November 7th, 2006 10:59 PM
Quick Reply: Truck will not start when raining or very humid
