Notices
Sponsored by: DashLynx
Trying to Bleed Rear Brakes and no pressure
Old June 12th, 2012, 1:23 PM
KGJC616's Avatar
Question Trying to Bleed Rear Brakes and no pressure
hello everyone, so here is my problem.
ok so i blew out the main rear brake line and and the front res when dry. i replaced the line form the abs system all the way back to both wheel cylinders. while i was at it i changed my shoes and springs/adjusters as well.
so i have everything hooked up and ready to go and yesterday i was trying to bleed the brakes, so i had someone pumping up the brakes a couple time then i would open the passenger rear bleeder and the fluid would just slowly dribble out with no pressure to it, and the brake pedal would not go down at all.
so i close the bleeder and pumped the brakes again and nothing changed but there is alot of pressure to it.
my truck is a 1989 Silverado C2500 5.7 2WD with rear ABS
any help would be great thanks
Old June 12th, 2012, 2:28 PM
kevinkpk's Avatar
Did you bleed the master cylinder? If not, you will be forever bleeding it from the rear bleeders.
Old June 12th, 2012, 6:18 PM
KGJC616's Avatar
thanks kevin.
also will i have to bleed the ABS system? becuase i have no clue on what im supposed to do with that.
Old June 12th, 2012, 6:39 PM
KGJC616's Avatar
quick question.
for brake line and transmission lines would it be better to use just a standard flare, or a double flare.
Old June 12th, 2012, 7:31 PM
kevinkpk's Avatar
Originally Posted by KGJC616
quick question.
Double flare is on both sides of the flared end. I don't know with automotive, but double flare is always better. It won't make a difference to the B nut, just more UMPH on the the arm to flaring tool
Old June 12th, 2012, 7:34 PM
kevinkpk's Avatar
thanks kevin.
Don't think other than the MC, auto parts store sell cheap bleeder valves for the MC, probably 2 bucks. Terms in the past such as "bench bleed" a new MC was that, you put the MC on a bench, with one hand pumped it up, the other beld off the air.
Old June 12th, 2012, 7:50 PM
you need a 45 degree double flare. single flare will not stand up to the potential psi the sytem develops and will leak. Do not run straight lines.
if the system has a proportioning valve you will need to insert a tool to open the valve to bleed the rear brakes. The p valve, if present, is usually part of a junction block, connected to the lines out of the m/c. The junction block is silver and has a rubber plug and paper tag on the front of it.
gravity bleeding the system with the reservoir cap off will speed up the bleeding process.
Old June 12th, 2012, 8:46 PM
kevinkpk's Avatar
I don't think you can get anything other than a dual flare tool.
Old June 13th, 2012, 12:38 AM
KGJC616's Avatar
thanks you guys. tech, what tool would i use on the proportioning valve?
also the front brake reservoir never went dry and i haven't done anything to them. could i get away with just bleeding the rear brake reservoir?
I ask this because im almost positive that if i try and loosen the front caliper bleeders they will probably snap right off or i might run into other problems and have to replace the calipers. and at the moment I dont have the money to replace them, but if i cant get away with doing this ill just have to wait a little while before i can buy new parts.
Old June 13th, 2012, 8:41 AM
RacerX's Avatar
put some oil on the bleeder screws and let it set in before you turn them with the wrench. but you only have to bleed the circuit that went dry. but pushing fluid in the reservoir should push the air to the rear wheel cylinders.
Quick Reply: Trying to Bleed Rear Brakes and no pressure
