Turn OFF Check Engine Light? - Chevrolet Forum - Chevy Enthusiasts Forums
December 1st, 2007, 7:28 AM   #1
[hr]Besides having the codes cleared with a scan tool, what is the DIY procedure for turning off/resetting the check engine light?
December 1st, 2007, 7:30 AM   #2
RE: Turn OFF Check Engine Light?
[hr]Forgot to mention, above is in regards to a 1997 Silverado 2wd 5.0L.
tedco21's Avatar
January 13th, 2008, 1:41 PM   #3
It has to be cleared with a scan tool.
January 14th, 2008, 7:56 AM   #4
You gottafigure outwhat caused the check engineand fix the problem. Depending on the code or codes involved once fixed the light will stay off. A few codes will require a determined number of on/off "cycles" without error before it will go out. You can always erase codes by disconnecting the battery for at least a half hour. That resets the PCM. The check engine light will come right back on and stay on till you fix whatever iscausing it
cffcjoker's Avatar
SAN ANTONIO
January 12th, 2013, 7:32 PM   #5
I can reset service engine lightby removing the two ecm fuses and turning key on for ten minutes reinstall fuses start truck this is on a 2000 silverado worth a shot
Tags
Sponsors
