Notices
Sponsored by: DashLynx
Valve cover exploded while starting, engine help please!
Old May 13th, 2012, 5:05 AM
TBusey01's Avatar
Default Valve cover exploded while starting, engine help please!
Just bought a 79 chevy 3/4 ton and went to start it and it made a loud boom noise. Looked under hood and the valve cover somehow exploded, want to know what might have caused this and where to start on the engine.. or should i just find a replacement engine for the truck.
Old May 13th, 2012, 5:07 AM
TBusey01's Avatar
Old May 13th, 2012, 6:09 AM
Allan In NE's Avatar
Nothin' wrong with your engine,
You've had a crankcase explosion caused by the oil being saturated with gas. Change your oil.
Check that carb for leakdown/bad float, but most likely, this was caused by a bad choke setting.
Also, when you get it running again watch for oil leaks. You can just about bet that it blew the pan gasket and the other valve cover gasket.
Allan
Old May 13th, 2012, 7:07 PM
TBusey01's Avatar
Good to hear, ill mess around with everything and hopefully no more problems.
Old May 14th, 2012, 9:59 PM
Doug Roberts's Avatar
Wow first I seen this
Old May 16th, 2012, 7:28 AM
Former Sponsor
johntaps's Avatar
Post Valve cover exploded while starting, engine help please!
It might be the crankcase pressure due to excessive blowby.
Old May 26th, 2012, 10:08 PM
TBusey01's Avatar
did compression check, turns out the motor has no compression in at least 2 cylinders so time to swap out for different one.
Old May 27th, 2012, 1:10 AM
Site Ambassador
Camaro 69's Avatar
Did you take the valve cover off yet to inspect and make sure you didn't bust a valve spring or two, or something else? If valve train parts went flying apart under pressure, that could break the valve cover, and would also explain the no compression if those two bad cylinders are on the same side.
03Problemcar
September 26th, 2015 1:39 AM
ReiGnMaN454
March 26th, 2013 12:13 AM
TahoeMatt
February 28th, 2013 8:13 PM
stuman2
December 27th, 2009 1:05 PM
Rick Stallard
November 12th, 2008 7:21 PM
Quick Reply: Valve cover exploded while starting, engine help please!
