water leak into heater blower motor - Chevrolet Forum - Chevy Enthusiasts Forums
usmarine0905's Avatar
Raleigh NC
March 1st, 2010, 10:55 PM   #1
Hi, my 98 C2500,5.7 Vortec extended cab has a water leak into the heater blower motor. when the truck sits and it rains, water finds it's way into the blower housing. Anyone have any idea where this might be coming from??
Thanks
<!-- / message -->
<!-- controls -->
ristpin's Avatar
March 2nd, 2010, 4:11 PM   #2
Sure it's not anti-freeze? Does it have a "sweet" smell? Sounds like a leaky heater core to me. Check your radiator fluid level.
Rodehard's Avatar
Digital Dogpatch
March 2nd, 2010, 4:19 PM   #3
if leaf debris has clogged the drain holes in your fresh air intake, it will run in that area of the cab.
MDTAHOE's Avatar
Professional Mechanic
Bowie, MD
March 2nd, 2010, 8:38 PM   #4
Remove the wiper arms and then the cowl panel, you will most likely find crud in there causing water to go in to the box.
Raleigh NC
March 2nd, 2010, 9:37 PM   #5
@ rispin....its not antifreeze...just water. it only happen after it rains but thank you....
Raleigh NC
March 2nd, 2010, 9:39 PM   #6
@ MDTAHOE.....and RODEHARD....Thank you I will check that out this weekend. Also is it difficult to replace the blower motor assy, its started sqelling very baddly??
Tags
Sponsors
