Notices
Weak brakes on 2001 Silverado
Old September 1st, 2009, 6:14 PM
JohnnyG's Avatar
Default Weak brakes on 2001 Silverado
I have owned my 2001 Silverado (5.3l, Ext. Cab, short bed, Z71) for a few years now. It has always been very weak on braking. My biggest concern is that I cannot even get the ABS to kick in (unless on ice). I have new rotors and pads, had the brake system flushed and bled. One of my tests was driving it home one night when it was raining, on a straight stretch of road (no other traffic around) I stood on the brakes. From 25mph the truck just slowed to a stop. The ABS never made a peep. This tells me the hydraulic pressure is not enough to grab the rotors and lock up the tires. The dealer says this is normal, but my friend also has a 2001 Silverado - non Z71, if he lays on the brakes the ABS kicks in and there is a significant difference in stopping power. Could this be a problem with the master cylinder? I have also heard that air in the ABS unit could be a problem - but I had the system bled at the dealer. I refuse to accept that the brakes just naturally suck.
Old September 1st, 2009, 6:28 PM
ROTM Coordinator
Mike Sigmond's Avatar
Thats a good one, lets see what the service techs here have to say.
Welcome the the forum!
Old September 1st, 2009, 9:10 PM
lukemoore646's Avatar
is your tire and wheel combo stock?
Old September 1st, 2009, 9:32 PM
Professional Mechanic
MDTAHOE's Avatar
If it is stock then you need to have the hydraulic system pressure checked.
Old September 2nd, 2009, 10:54 AM
therewolf's Avatar
I've got the 4-wheel disc brakes, but I'll stack my 2500HD's braking ability up to the smallest import you can find. Where I live they have to be that good, or you couldn't survive in the traffic. There's always some cupcake in a Honda or Subaru jammin' on his brakes right in front of you here.
MDTAHOE's right again, I'd check the hydraulics. I've noticed a lot of brake shops don't bother bleeding the brakes when they're done the brake job.{God knows why.}
Power bleeding comes to mind. My girlfriend's 01-1500-4X4 stops on a dime.
Old September 2nd, 2009, 7:45 PM
JohnnyG's Avatar
Thanks all,
I am using stock wheels and tire size. It sounds like I should get the hydraulic pressure checked out next. It's too bad right now, aside from the brakes it rides like a Cadillac.
To be continued...
Old September 3rd, 2009, 10:44 PM
sounds like air somewhere to me, wider tires are harder to skid because they lay down a bigger footprint but thats not the case, how is the peddal, is it spongy or firm right at the top
dlf35121
Computer, Ignition, & Fuel Systems
March 4th, 2020 12:06 AM
LuciusII
December 27th, 2011 1:55 PM
Foxracing
March 17th, 2008 7:35 PM
5ilverado
Audio/Visual Electronics
July 8th, 2006 8:09 PM
mountandriver
February 8th, 2006 8:22 PM
Quick Reply: Weak brakes on 2001 Silverado
