Notices
Emergency Brake Indicator Light
Old July 10th, 2007, 2:07 PM
bkordrs's Avatar
Default Emergency Brake Indicator Light
The Emergency Brake Indicator remains lit after I release the brake. When I engage the brake the indicator light brightness increases.
Old July 10th, 2007, 2:23 PM
cheyenne06's Avatar
Default RE: Emergency Brake Indicator Light
The light is activated by a pressure switch on the pedal. Check to see if the switch is out all the way when released. If it is, check you brake lights to see if they all work. Some vehicles have a setup where if a light goes out, a light on the dash lights up.
Old July 10th, 2007, 3:07 PM
techrecruit's Avatar
Usually an indicator of a faulty brake light or tail light
Old July 10th, 2007, 4:18 PM
golfer's Avatar
ORIGINAL: bkordrs
Does it light even though you don't engage the park brake ?
If it does there may be a problem with low brake fluid or the sensor.
Old May 15th, 2011, 11:05 AM
gemlam's Avatar
I am having a similar problem. When I release the emergency brake, the warning lamp does not go off completely - it stays on very dimly. Even when I turn off the ignition, and remove the key, the lamp stays on very dim.
jg33
January 3rd, 2021 3:17 PM
jrsavoie
July 19th, 2012 2:36 PM
diane888
August 8th, 2007 4:38 PM
diane888
August 5th, 2007 9:46 PM
LouisT
November 13th, 2006 6:54 PM
Quick Reply: Emergency Brake Indicator Light
