Why won't engine switch to closed loop? - Chevrolet Forum - Chevy Enthusiasts Forums
Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Current Chevy Trucks, SUV's, Crossovers & Vans > Silverado & Fullsize Pick-ups
Log In
Search
Sponsored by: Bakliner
LinkBack Thread Tools Search this Thread
Old 02-28-2010, 11:53 AM
Default Why won't engine switch to closed loop?
It is a 97 4.3 vortec, but only runs in open loop, and runs lean at that.
What makes the engine switch to closed loop?
And shouldn't it run rich in open loop?
Old 02-28-2010, 03:26 PM
I would think that it would run rich in an open loop. Have you checked your O2 sensors? Your truck should run open loop until the O2 sensors warm up and tell the computer if your truck is running too rich or too lean.
__________________
'02 Chevy Tahoe Z71 5.3L
performance upgraded
My Garage
Click for pics
Old 02-28-2010, 03:34 PM
the o2 sensors say it's running lean in the open loop, and it never goes to closed loop
Old 02-28-2010, 04:21 PM
What I meant to say is have you changed out your O2 sensors? They might be bad. If I remember correctly, the computer runs open loop at start up and goes to close loop once the O2 sensors give a reading back to the computer. From here the O2 sensors' readings will tell the computer if you're too rich or too lean. And I don't know what to tell you on running too lean. I think that the O2 sensor is giving a false reading (on account of it being bad) and is also the reason why it's staying in an open loop. How many O2 sensors do you have?
__________________
My Garage
Click for pics
Old 02-28-2010, 05:12 PM
4 o2 sensors, the readings they send back to the scanner say bank 1 is lean
Old 02-28-2010, 05:41 PM
maxxman04's Avatar
http://www.facebook.com/home.php?ref=hp
most o2 sensors are heated by an electrical current. the truck will run in open loop until the sensors reach a certain internal temp and send a signal to the computer. as long as sensors are good, the computer will switch to closed loop once it receives the signal. vacuum leaks, worn o2 sensors, bad plugs/wires/cap/rotor can cause ecm to run open loop while it searches for the proper signal. if your rig has over 100k on it and you don't know when the last time they were changed, change them.
__________________
rednekper4mince. keepin duct tape and bailing wire in business.
Old 02-28-2010, 08:04 PM
after all that i found a cut in one of the wires off the o2 sensor, fixed the wire, seems to have fixed the problems
Old 02-28-2010, 09:49 PM
maxxman04's Avatar
that is sweet. funny how sometimes it's somethin small and simple like that. glad ya got it fixed
__________________
Old 02-28-2010, 10:13 PM
nice.
__________________
My Garage
Click for pics
Similar Threads
Thread Thread Starter Forum Replies Last Post
WHY WHY WHY!!!!! xeqshnr HHR 22 02-13-2015 10:18 AM
2000 tracker dome lights won't go out when doors are closed lilrafe87 Tracker 2 01-04-2014 04:38 AM
Rear Door stuck closed latch won't open Hotwires Cavalier 3 02-14-2012 10:03 AM
Oxygen Sensor/O2 system stays in closed loop?? Mike Sigmond General Tech 14 05-12-2009 09:36 AM
Ground loop sawyerd Audio/Visual Electronics 0 01-02-2009 01:46 PM
Tags
03, 1995, chevrolet, closed, engine, gm, loop, open, oxygen, rich, running, sensors, tahoe, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
