Will installing a stereo effect your warranty?
Well the title says it all. I have a new/used truck with a 4 year warranty, I hate the stereo and have a complete system ready to put in, will this effect my warranty at all. Maybe if I had a shop do it instead of doing it myself it would help.
i don't want to have this installed and than down the road have a totaly unrelated problem where Chevy say's "you modified this truck so now your stuck".
Thanks
Thanks
Well if you take it in with say a failed oil pump, and they tell you they can't fix it because of your radio, fight with em about it. They can not prove that radio made your oil pump go out, no way in hell that'd happen. The only way they can say they won't fix something mechanically is if they can prove that whatever mod you did to your truck is the reason that the specific part went out
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Gixxerific,
Are you referring to the 98 K2500 7.4 listed in your profile? If not, what year and model is the vehicle?
Louis
GM Customer Service
Louis
GM Customer Service
bobbyj
March 21st, 2015 12:45 AM
nabochevy
August 14th, 2008 9:35 PM
