Won't run, HELP
Won't run, HELP
I replaced the intake gasket, went well. Complete new distributor put in, but the only way it will run is by pouring gas down the throttle body . It tries to Start on its own but won't. Could it be fuel pressure regulator?
Sorry should have put that info in. I managed to get it going last night, after replace ing the complete spider assembly. Now I'm getting " camshaft to crankshalf correlation " code. It runs smooth. It's a 1998 with 5.7 . Any ideas on the code?
Thanks
Thanks
Usually, that would concern timing, but it's not that simple.
You may have the distributor gear off by a tooth or two, at
the cam. Or the timing chain could be stretched and have slipped,
or timing gear teeth broken. Some of the old factory L blocks used
Nylon timing gears.
What is the mileage? Original engine? Has it been run hard?
Nylon timing gears.
jkemp101
Silverado & Fullsize Pick-ups
August 28th, 2013 11:44 PM
larryntripp
October 23rd, 2008 8:13 PM
icandoit
September 3rd, 2007 8:46 PM
