Sea Foam
i use it in the fuel systems of all my vehicles
also use it in all my small engine fuel tanks.
Enothol fuel is rough on the small engines and a small amout of seafoam in the tank has kept them running strong.
I have used Sea Foam for a long time and it is truly a great product, put some in the oil and just once in the tank, My dad uses it in his Diesel and he has never had his truck run any smoother.
Top of my list. Use it one a year in my oil,run it about 50 to 100 miles than change oil. What a diference it makes !! when i first used it i had a tapping in engine when I would first start it up for a couple minutes. After using Seafoam on oil change noise gone and has not came back since, also fell slight power increase!
Pretty sure on the bottle it has a suggestion of 1/3 in your tank, 1/3 in the crankcase, and 1/3 through the intake (brake booster vacuum hose). And yes, you just put it in the oil fill spot.
