Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
2009 Aveo Ignition Problem
Old June 25th, 2014, 4:26 PM
  #21
drecar's Avatar
Default 2009 aveo wont start
I sold a pre-owned 2009 aveo. the customer is complaining about intermittent starting problems. we have not been able to find the fault like many other internet users. reading through this forum I have seen ecm reflash with sync to immobilizer and replacing ignition switch as possible remedies. is this the proper solution to this problem?
i'd appreciate help asap on this.
thank you.
Old July 25th, 2014, 5:28 AM
  #22
Ida713's Avatar
My Aveo has been the worst car I have ever bought. I've had Fords and VW's but this takes the cake. I have had so many issues with it. The latest problem I have is my car wont start, unless I hold the key in... then slowly the lights come on... and if it feels like it, it starts. It seems to be an electrical issue with the car. Because of this my car radio has also died. My mechanic has said that it is the starter. Is it the starter? And do I now have to replace both the starter and the radio? $$$$$$$!!!!!
Old September 9th, 2015, 10:50 AM
  #23
myudderplace's Avatar
Default ECU type
I am having a cranking problem with my 2009 Aveo.
I purchased a tech manual and have looked at Chiltons online. There are a lot of variations on schematic. How can I tell which schematic I should be using?
MT-80 etc.
Old November 29th, 2016, 10:45 PM
  #24
Charles Elledge's Avatar
Originally Posted by jtdreiki
I took the car back to the dealer and the new bulletin for this problem was to reprogram the ECM and then synch it with the Anti-Theft System. So far so good.
Would love to know that bulletin number....
Old March 8th, 2017, 11:13 AM
  #25
WyrTwister's Avatar
Is it showing a check engine lite / service engine soon ?
Read the codes , even if it is the code history or pending code .
Then you will have more information to go on .
God bless
Wyr
frustrated
Sonic (Aveo)
12
August 3rd, 2015 8:47 PM
starladustangel
Sonic (Aveo)
16
May 10th, 2015 4:59 AM
charliehustle14@hotmail.com
Sonic (Aveo)
October 13th, 2014 12:00 AM
mmtronic
Sonic (Aveo)
March 11th, 2009 3:23 AM
xfly
Sonic (Aveo)
December 30th, 2008 1:50 PM
Quick Reply: 2009 Aveo Ignition Problem
