Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Aveo Door hinges hard to open-lubrication
Old March 16th, 2013, 1:02 PM
Jerry32's Avatar
Default Aveo Door hinges hard to open-lubrication
Hi,
We have a 2006 Chevrolet Aveo LS and several of the doors are getting hard to open. Is it OK to use WD-40 to spray on the hinges, or do I need a specific item? Thanks!
Old March 16th, 2013, 1:34 PM
tymr287's Avatar
According to Chevrolet, use engine oil on all hinges even the fuel door.
Old March 18th, 2013, 5:27 PM
Jerry32's Avatar
really-never would have thought of that--thanks!
Old June 17th, 2013, 6:20 AM
wrobbin's Avatar
What you need to lube the door hinges is a grease gun and needle tip fittong. In the middle of each hinge is a small dimple, or depression. That is where you lube the hinges. Just stick the needle tip tight into the dimple and pump the handle a couple three times
Old June 17th, 2013, 9:33 AM
I would suggest a spray can of white lithium grease...
country_09
Silverado & Fullsize Pick-ups
December 5th, 2023 5:48 PM
mrpep
Express & G-Series Vans
May 10th, 2015 8:40 AM
jogodlew
16
June 21st, 2014 11:02 AM
gojaxon
February 15th, 2011 8:32 PM
JudyK
November 8th, 2009 7:09 PM
Quick Reply: Aveo Door hinges hard to open-lubrication
