Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Oil on spark plugs
Old January 5th, 2010, 6:55 PM
peedeefish's Avatar
Default Oil on spark plugs
My wife drives an 04 Aveo. The engine light came on, so I used my diagnostics computer on it. It gave me a code for misfiring. I changed the spark plugs and wires, and when I removed the spark plugs, all of them had oil on them. But after I changed them, the engine light went off. Does anyone know why oil might be on the spark plugs.
I was reading about it, and most people said the valve cover might be leaking. But on the Aveo the spark plugs are on top of the engine. I really don't know much about it though.
Thanks for any help.
Old January 6th, 2010, 10:49 AM
myotherchevyisablazer's Avatar
Wet, oily deposits. Will cause weak spark and eventually misfire.Fault: worn bores/piston rings or valve guides; sometimes occurs (temporarily) during running-in period. Plugs can be re-used after a thorough cleaning. For Pictures.
On the outside of the Plug. Oil would be from a Leaking Gasket or Seal
this is just what i found,hope it will help in your quest for answers...good luck i have been there
red
Old January 6th, 2010, 3:51 PM
gotstylez's Avatar
i'd pull a plug or 2 out in about 200 miles.. see what it looks like.. then u might be able to take it to a dealer or sumthing and see what they say
Old January 16th, 2010, 10:27 PM
BlazerLT's Avatar
I can see that people replying in this thread really haven't owned a 4 cylinder before.
Having wet oil on your threads when you remove plugs is from a little teeny bit of oil seeping into the spark plug tubes in the valve cover and thus when you remove the plug you get oil on the plug threads.
This is no way means there is oil in the cylinders at all and you are more than likely perfectly fine. The amount of oil in the tubes is almost nothing and not worth worrying about.
Drive on and enjoy.
Old January 16th, 2010, 10:29 PM
gotstylez's Avatar
v8 or nothing..and besides i was just trying to help
Old January 16th, 2010, 10:31 PM
BlazerLT's Avatar
Best to maybe stick to the V8 threads then.
silverado2001
Silverado & Fullsize Pick-ups
10
December 16th, 2020 3:45 AM
LS Silverado
September 20th, 2012 4:00 PM
kamiakin2
September 11th, 2010 12:30 AM
catill
August 30th, 2010 11:07 AM
Quick Reply: Oil on spark plugs
